I've got a bit of a dilemma re my two CPUs, I bought the 860 because I was having a heck of time trying to stabilise my system while running 8GB RAM at 1800Mhz-2000Mhz. That issue isn't completely solved and the 860 is only a little better as it can run the x12 memory multiplier. I need to decide fairly soon which CPU to keep and which to sell (I can't afford to keep both)
The i7 860
The i5 750
The memory problem
I don't need to run the RAM at full speed particularly, but having spent the extra cash on it I'd like it to be running at least somewhere near spec. I put a longer description of what happens on a thread in the memory forum: http://www.overclockers.com/forums/showthread.php?t=639992
The questions
The i7 860
- It seems stable at BCLK 161 and 'auto' multiplier ( 3.38GHz) with C-state enabled. So I think Turbo mode will work like this. Arguably a pretty decent compromise for an everyday/gaming system. However it does seem to run quite a bit hotter, hitting 80°C and requires maybe an extra 0.1V-0.2V compared with the 750.
- I think can get the temps down a bit with voltage tweaks and re seating my cooler (Corsair H50) but I feel there's not much headroom if I want to push the CPU at a later time
- 860 seems less happy with higher BCLK and x10 memory compared with the 750
- It will boot into windows at BCLK 167, but ram is at 2004-2009Mhz and I suspect 8GB will never be stable that high
The i5 750
- 750 can do 3.6GHz-3.8Ghz with no effort on 4GB RAM and I suspect it would crack the 4Ghz barrier if I was willing to volt it high enough. With lower clocks I imagine it will be possible to get c-state working, and stabilise with all 8GB memory installed
- However at anything over 195 BCLK with 10 memory multiplier 4GB is always disabled and unavailable, I've got to the point where I think I would have to use a much lower RAM speed to get proper stability with the 750 / 8GB combination
The memory problem
The questions
- does anyone have tips on how to get more speed from an already hot 860?
- does anyone have an idea of how to get 8GB stable at high BCLK with i5 750?
- I notice that the Lynnfield overclocking guide on this website suggests 1.35V on VTT - is this really safe? I thought that is hugely over spec for these CPUs. I briefly tried 1.36V, but it made no difference anyway.
