i7 860 stable but 1 core on cpuz
lekt
Brooklyn,NY
My 860 OC'ing great, but it only shows 1core, games are stutering .
I reset cmos, went back to stock (TH,HT ect) enabled nad still one core.
Any help??? Thank you......
redduc900
Inactive Moderator
Portland, OR
Assuming you're running a MS OS, type msconfig either in the Run box or the Start Search field. Select the Boot tab--> 'Advanced options' button, and check that the 'Number of processors' box is not checked. If it is checked, uncheck it and reboot.
