i7-920 @ 4.2ghz stable - feedback wanted
simviatoR
Can anyone give any feedback/suggestions on whether to tweak anythign further? Is 1.305v fine for where I am at?
Boulard83
+1 above ;)
If hese are load temps, your cooling is AWESOME ! :D
Run a Prime95 with Small FFT for at least 20-30 min and pots temps.
creecher
New Orleans area
no, they're not load temps, look at the top of the temp thing, it says load = .9%
there actually a little cooler than mine, mine are about 3 degrees higher at 4.3ghz on my 920
Bullant
Sorry, OCCT for 1 hour, max temps are around 68*c - watercooled.
Hi sim,
I would use prime95 to test if your overclock is stable,that will stress your NB alot more.Also try testing with linX,it will really see if your clock is stable.But keep eye on ya temps:sly:
