I have decided to upgrade my existing desktop as it has been a while and it could do with some more oomph, especially as I plan to start using it for running adobe elements once I get using my new 14.2 Mp DSLR and it also struggles when doing multiple threads of video encoding / parring and rarring etc.
Will be used for:
Web / Email
Downloading
HD Video editing (basic cutting / joining / format conversion)
Tools like Quickpar / Win Rar etc. (multiple threads at a time)
Photoshop
I am trying to decide whether to go with the much talked about Q6600, or spend another £200 or so and go i7. I really like the Antec Sonata III Piano Black Quiet Mid Tower Case - which comes with a 500W EarthWatts PSU. Not the highest powered PSU, but am hoping 500w will be enough as I don't need mega graphics for what I do (have been running onboard graphics for the last 2 years!!)
My dad is having this machine, so I am starting from scratch, although I am keeping the two Samsung Spinpoint 750GB SATA 300 32Mb HDDs and the Blu-Ray / HD DVD / DVD RW combi drive that are only a few months old as well as the Vista Home Premium 64 Bit license which I will transfer to this machine, and replace with XP, a DVD RW drive and an older 250Gb HDD (more than enough for him!!).
Will connect up to my Apple 20" Cinema display, not full 1080p HD but close enough ... for now!
I have already decided on the Q6600 if I don't go for the i7.
All prices are ex VAT as purchasing for company use ...
Either 'budget' high end system:
Total Cost £296.53 (+ case)
or higher spec:
Total Cost £530.80 or £554.19 depending on the heatsink
Overclockers do an i7 bundle with an i7 overclocked to 3.3Ghz for £434.77:
Adding in the GFX card makes £500 ish, but the cooler in the bundle looks a bit pants. That bundle also uses a Gigabyte mobo as opposed to the Asus in the original spec, which is £30 cheaper in itself, hence the price drop from the £530 mark. I assume it is 'guranteed' to overclock to 3.3Ghz which is nice, however I have seen lots of guys here clocking way past that with the i7s, so maybe more is possible if I just pick a standard one?
So what are you thoughts people about spending almost double to get the i7 processor and the extra, higher spec RAM? Graphics card will be the same, as is most of the rest cmopared to the Q6600 package, I just really liked the Antec case and it has gotten some good reviews for being a quiet PSU, all at a good price!
Anything you would change on either option? I toyed with a different fan for the Q6600 but the Akasa one was only £4 more in the bundle and I can always change it later if I want, once I start trying to overclock it.
Recommendations for other mobos / gfx options also appreciated. Don't really want to spend more than about £60 on GFX as this is not a gaming rig!
Will be used for:
Web / Email
Downloading
Photoshop
- Gigabyte EP45-DS3L, iP45 Express, S 775, PCI-E 2.0 x16, DDR2 1066/1333/1600, SATA II, ATX at £69.99
- Intel Core 2 Quad Q6600 G0 SLACR, Kentsfield Core, S 775, 2.40GHz, 1066MHz, 8MB Cache, OEM+Far Cry 2 & Akasa AK-960E Intel LGA 775, Dual/Quad 3.8Ghz+ 3 HeatPipe, Aluminum Fin Heatsink, PWM Fan & EBR bundled together at £129.66
- 4GB (2x2GB) Corsair TwinX DDR2 XMS2, PC2-8500 (1066), 240Pin, Non-ECC Unbuffered, CAS 5-5-5-15, EPP at £43.99
- 512MB Sapphire HD 4670, PCI-E 2.0 (x16), 2000MHz GDDR3, GPU 750MHz, 320 Cores, D-Sub/ DL DVI-I/ HDMI £52.89
or higher spec:
- Asus P6T, Intel X58, S1366, PCI-E 2.0 (x16), Triple DDR3 2000(OC), SATA 3Gb/s, SATA RAID, ATX & Intel i7 920, Socket 1366 (B), Nehalem, 2.66GHz, Cache 8MB, Retail + Far Cry 2 bundled at £375.92
- Akasa Nero AK-967 Intel LGA 1366 Heat Pipe cooler, 120mm PWM fan at £22.00 or NH-U12P-E - Noctua NH-U12P SE1366 Exclusive Dual Fan CPU Cooler, LGA1366 only at £45.39
- 6GB (3x2GB) CorsairXMS3, DDR3 PC3-10666 (1333) 240 Pin, Non-ECC Unbuffered, CAS 9-9-9-24 £79.99
- 512MB Sapphire HD 4670, PCI-E 2.0 (x16), 2000MHz GDDR3, GPU 750MHz, 320 Cores, D-Sub/ DL DVI-I/ HDMI at £52.89
- Intel Core i7 920 2.66Ghz (Nehalem) @3.33Ghz
- Gigabyte EX58-UD3R Intel X58 mobo
- OCZ 6GB DDR3 PC3-10666C9 1333MHz Gold (3x2GB).
- A heatsink & fan (not sure what, put looks quite puny!)
