I have a 920 D0 stepping and cant seem to get a stack 4.0ghz
I just got my megahalem rev b with 2 S-flex SFF21F fans running at 100%
I went thry matts thread and some other threads and started at:
BCLK 200
20x multiplier
1.25v cpu vcore
1.65v vDIMM
1.25 QPI
C1E enabled
speedstep disabled
mem ratio is 2:8 at 7-7-7-24 1t command rate, running 1600mhz
I turn on realtemp, linX and cpu-z.
Idle temps were highest at 40 and lowest at 38
I ran linX, using 2gb ram, comp crashed within 15 seconds, load temps got to 65 before it crashed.
Next I brought my cpu Vcore to 1.75v, ran linX, so far stable... 5m into test; highest temp atm on full load 100% is 69-73
So now first question, my idle temps are high 30s, low 40s... good or bad? If this OC is stable, should I lower my cpu Vcore or up my GHZ to 4.2? I dont think ill want to go over 4.2ghz. What should I let my max temps get to before I should stop my OCing?
UPDATE: LinX at 10m so far, stable; gonna take wait another 50m and see how it goes.
UPDATE 2: LinX 20m stable and going.
Question id like to figure out fast: My fan controls in my bios, I have a CPU fan controller, a power fan controller and chassis fan controller... I had to plug in one of my 2 fans on my megahalem into the CPU fan header that is next to the ram... What is that fan header suppose to be in bios? Power fan or chassis fan?
Gonna post this and edit it as time goes on...
BCLK 200
20x multiplier
1.25v cpu vcore
1.65v vDIMM
1.25 QPI
C1E enabled
speedstep disabled
