i7 build
onefstsnake
Fburg, VA
Buying an i7 920 D0 this friday and making a list for my new rig.
Mobo- ASUS P6X58D Premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
Memory Im not really sure yet. I want to run between 6-8gigs.
Cooler- Corsair H50
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
I like the fact that its simple, Im tired of messing with huge heatsinks.
Case + PSU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.304271
750w enough for two GTX260's?
HDD- WD Black 500
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
Thanks!
Shadowmonk
That corsair obsidian case is built for full water cooling, if your using the H50 might i suggest saving yourself a bit of $$$ and going with the coolermaster HAF 932 case? That would give you more headroom to play with for the memory, im running 6g of Kinston Hyperx 8-8-8-21 @ 2000mhz and its great memory.
onefstsnake
onefstsnake
Fburg, VA
I really like the G.Skill RipJaws but wouldnt four sticks be quad channel?
Also not a big fan of the HAF...
Anyone using the Ultra M998? Looks very nice.
Shadowmonk
The Ultra m998 is a damn fine case too. I would tend to steer towards the Ultra m923 full tower if your going to be using SLI just so the cards have plenty of breathing room. If your looking to use the G.Skill Ripjaws there are the triple channel kits available. Going i7 id stick with the tri-channel sets because using 8gb is going to void the tri-channel advantage in bandwidth.
Unless your doing some heavy rendering I see no point in anything above 6gb atm.
1600 ripjaws tri-channel
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304
2000 ripjaws tri-channel
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231306
Trident 2000 tri channel kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231254
onefstsnake
onefstsnake
Fburg, VA
I plan on folding with the rig.
With the new Big WU's 6gb of ram is minumum.
Im kinda torn between a case with a window or no window.
Silverstone makes some really nice looking cases but dang they are pricey.
onefstsnake
onefstsnake
Fburg, VA
Stacker 830 Evo?
As for memory I was thinking 4x2 for 8g total.
there are a few 3x4 kits though.
Shadowmonk
I would recommend using (2) 3 x 2gb kits as the mobo itself has 6 slots available, allowing you to use the full bandwidth available for the ram. The Stacker Evo is a nice case as well, alot of features i like in it and good cable management.
onefstsnake
onefstsnake
Fburg, VA
Ok cool.
Hoping I can get this thing together and running by christmas.
Ill be sure to post some pics when its done.
Thanks for the help.
Shadowmonk
Those sticks will run damn nice for ya, ive always used g.skill product until my last build and only becuase kingston also lifetime warranties the hyperx series. I got a great deal on the ASUS WS Revolution mobo and since i had 3x GTX 260's i figured i might as well put them to good use. I'm truly amazed at the difference in tri-sli going from the EVGA 780i and q6600 oc'd to 4 ghz to the i7's much better scaling for tri-sli. Get that puppy up and running and lets see some screenies!
onefstsnake
onefstsnake
Fburg, VA
Well It will be a few weeks till I have everything. Got bills to pay lol.
friday Im buying the i7 920 D0 and the Asus mobo.
Next paycheck will be the case, ram and PSU.
So might not be up till after christmas. Ill still need a GPU and HDD and another copy of Win7
onefstsnake
onefstsnake
Fburg, VA
Well making some progress to finishing this thing.
Stopped by Microcenter today and picked up some goodies.
-HAF 932 case
-Win7 Home Premium 64 bit
-Corsair H-50 rev2
-4 Xigmatek white LED fans 120mm
Already dissasembled the case to paint the inside black.
Ordering the Mobo and RAM tonight. Only going with 6gb for now (limited cash). Recycling a 500gb WD Blue drive from my main rig.
Not sure what Im going to do for a GPU just yet. Might swap the 8800Ultra from the HTPC to the i7 rig till I get some cash for a GPU.
Ill start a new thread for the HAF 932 painting soon.
