i70-920 goal - 4.5ghz
simviatoR
on WC loop, can anyone suggest a good template to get started for 4.5? seems no matter what i try, it will not boot to windows.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Template...just keep on trying. What are you major voltages set at? Thats a pretty lofty goal....
CompuTamer
Member with Some Fancy Text Under His Name
Brandon Mississippi
You see the CPU speed in my sig?
Took me a year to get it to boot at that speed, and i'm still working kinks out of it. (like random lock ups when folding on the GPU).
So you're going to have to play with it... don't be afraid to set it back to stock/lower your OC for a little while and try again later though :)
What stepping is your chip?
simviatoR
simviatoR
D0,
im currently @ 4.2ghz, 1.305 and never touch 60*c during stability test over an hour.
I just need a good starting point.
EarthDog
Buckeyes!
I mentioned in my post above to list your major voltages. That will help the real experts in i7 give you at least an idea of where to go. But there isnt a cookie cutter setting that is magically going to get you there. As I said above, thats a lofty goal for 24/7 stable. GL, and I will be checking back. :)
CompuTamer
Brandon Mississippi
Than keep going... shouldn't have to worry about much of anything till you hit 1.4 volts... need to really watch temps after that though.
Make sure your IOH doesn't have a crappily applied heatsink like mine though.
