- Oct 14, 2008
Does the below look ok/safe for 24/7 OC, I will be gaming mostly and the temp never go past low 70's. I'm more concerned/confused about the Vcore, i have set 1.38 Vcore in the bios for 5.2Ghz, cache ratio 49, LLC 6 and all is stable. I will also be deliding the CPU to try drop 5-10C.
FYI, i am running dual 420 rads and a single D5 pump with a 3090FE in the loop.
I'm most confused between VCORE and VID #0-9, which one shows the actual voltage the CPU is receiving?
