- Mar 1, 2019
- China
Hi Guys,
One of my friends just bought an i9 9900K. He asked me to help him with an issue that he is facing with regards to the thermals in his system. Before I can visit him and see what is going wrong with his system I thought it would be good to have a small discussion with you guys here.
Now the problem is that even without an Overclocking profile both on Ram and CPU, his system just crashing on Prime95 29.8, sometimes he gets a BSOD and sometimes the system completely freezes. His cooling is not a problem as he is on Custom Loop with an EK Vector block. He told me that his temps were as high as 98-99 degrees (Hwininfo) as soon as he starts Prime95. He told me that he was running the small FTT Test w/o any overclocking. What is strange in this scenario is that he informed that his system is thermal throttling all the time and he sees some of his cores (#Core 4, #Core 7)completely greyed out. Also he did inform that Prime95 was showing some of his cores mentioning Stooped Working and that the temps on #Core 4 & #Core 7 were consistently 99 Degrees and were showing to be thermal throttling.
Ohhh Yes before I forget his Ideal temperatures were 45-50 degrees even though the pump was running at higher RPM's and his Rads are same as mine Alphacool X45 420MM copper radiator. He has a very good airflow in his system(he is using a Thermaltake View 71 case).
Any idea what could be the problem, I seriously suspect that he has a very bad CPU...
Rgds
Sajeev
Rgds
Sajeev
