IBM Aptiva
Lozip
Fredrikstad
I have a Aptiva pc with a Intel P. II 350Mhz. I have recently considered over clocking my computer and
I have some problems.
1. I cant find the multiplier switch on my motherboard.
2. Over clocking a slot 1 processor isn’t the easiest thing. I have seen many things on the net I would like to get some guidelines.
My computer is a IBM Aptiva model 2139.
Here you can find some info about it:
INFO ABOUT 2139
Please help me.
Lozip
Ebola
Senior Toilet Scrubber
Rosemount, MN
1. welcome to the forums. sorry to say it but your not going to have much luck with an ibm computer.
2. that ibm computer probably uses an intel motherboard with an ibm custom bios. it probably has no overclocking options available.
3. you can't change the multiplier on pentiums. you overclock by changing the front side bus.
4. there is a program on the net called soft fsb. it might work but no garauntees.
