- Mar 1, 2002
- Budapest, Hungary
Well. Closed the case, lowered fans rpm and now dual prime95 fails after one hour
Clevor said:These 2.40Cs hit a wall at some point. NOTHING will work except dropping the fsb maybe 1 mhz, if you are lucky. I've found adding more voltage above 1.6 is no help (if your CW board can actually deliver this).
If ya think your rig is stable, see if it can pass all this:
- All three 3DMarks. Some CW boards hate 3D2001, some 3D2003.
- SuperPI 16M run, should take 30'
- Serious Sam 2nd Encounter demo loop, this is real sensitive to CPU stability
- IL-2 Sturmovik demo loop, this is also real sensitive to CPU stability
- PCMark2002. Lately, on the CW boards, I am seeing I can pass all the above but this keeps rebooting until I drop fsb 1 mhz
- VulpineGL, same with this one
- Codecreatures
- UT2003 bench
I thought I was at 292 fsb and 3.5 gig on air, with a highly touted L310xxx Malay (Memtest clean in everything here), but had to drop all the way down to 287 to pass everything above .
ozziegn said:the stock Northbridge cooler on the IC7 is a joke.
while the fan itself is pushing a decent amount of air, the actual heatsink itself is too small thus having very little actual cooling surface.
that being that, I changed my NB cooler to the one in the pic and I have noticed more stability in my system. the cooler itself was very cheap ($10 @ Comp USA) and took me all of 30 minutes to put it on. I just had to grind off the four corners of the cooler so it could be attached with the chrome ring.
