IC7-MAX max fsb 230?
vigilante
Netherlands
My ic7-max won't go over the 230mhz fsb..... :bang head With my asus p4p800 deluxe i reached a stunning 265fsb on stock cooling..... :D anyone a suggestion? i already locked the agp/pci ratio to 66/33. the memory is running 1:1 at the moment @230mhz. i tried 5:4 and 3:2, nothing helps.
My specs:
P4 2,6C stock cooling
Twinmos 1024Mb ddr (dual channel)
Prolink Geforce FX 5900LE running @ 485/875 with zalman ZM80-HP cooling..
zalman 300W
120Gb seagate baccaruda s-ata
spiral529
Gainesville, FL
What happens when you try to pass 230fsb? Do you start getting errors, or just no POST? If everything in your system is the same as with your p4p800, it must be something with your board. Check your RAM timmings, set your GAT settings to A-A-A-D-D. You can update to the latest BIOS revision if you haven't done so already.
