- Mar 19, 2001
- Dallas, TX.
I recently took ownership of the Abit IC7 Max3 and have been very pleased with the performance so far. I have a 2.4c running and 512 of CorsairDDR TwinX (500mhz).
Thanks to all the information you all have provided, I was able to start overclocking this chip on up to 265fsb. One interesting problem I am running into is when I attempt to change the DRAM Ration from 1:1 to 5:4, the machine will not boot past the standard CPU settings (12*200fsb)2400mhz. It seems like I am hitting a wall with the 1:1 settings and curious if you all have any advise. I upgraded to the most recent BIOS from the ABit site so I'm not sure if that is the issue.
My DRAM TIming settings have stayed at 4-7-3-3. I changed the GAT to Auto-Normal-Auto-Dis-Dis. DRAM voltage at 2.8
My cooling is the Corsair HydroCOOL 200 (love it). CPU temp never gets above 35c
Should I change the N/B Strap in the BIOS to PSB800?
I have the CPU:AGPCI ratio set to fixed and the AGP/PCI ration fixed at 66/33
What am I doing wrong here?
