IC7-Max3 Vcore Voltage Issue.
InsaneO/cer
Hey guys,
Just got a IC7-Max3 for Christmas and got her all setup and running like a champ. The only problem is that in BIOS i can only choose up to 1.5volts for the CPU and the choices go down to 1.1volts. I cannt not choose anything higher then 1.5volts.
Any help?
Thanks
Proc is a 2.4c
Have you recently updated your bios? If not that might be what you need to do. If you have maybe update it with an older version it could be the newer version. On my ic7 max 3 with newest at the time bios i had selections up to 1.9v i beileve. I cannot go back and look to be sure my mobo is dead atm waiting to rma it after christmas. Those are the only suggestions i can think of at this time.
