- Nov 8, 2001
I'm thinking like a stoner on this one, but maybe I could make a bong for air-cooling...
Ok start with a 10 or 20 gallon fishtank. Make an airtight, removable lid from... let's say plexi-glass or lexan. Cut two circular holes in the lid and place a pvc pipe in with an L joint to route air to a case fan intake, and a length of clear tubing(enough so that it coils and sits at the bottom of the tank), or copper coil would be even better. The tubing/coil goes below the water level, the pvc pipe doesn't. Hook up a powerful fan to the pvc pipe to suck air from the setup, and cut that pipe so it fits right over my cpu intake duct. Make that joint air tight, and put a foam filter in the pipe to prevent any splashing. Stick ice water in the fishtank. Air gets pulled into the tank thru the tubing/coil, and thru the ice-cold water, then gets piped directly to the cpu.
I've got a 10 gallon tank and a limitless supply of ice. PVC, plexi, and silicone are all pretty cheap. I'd just need one hella powerful fan to overcome the pressure of sucking the air thru the water. What do ya think?
