idea for keyboard modding
fiji
berlin
ok i was thinking, (yes that is a once in a lifetime event for me ehehe ) about keyboard modding, and how im such a cheapass all the keyboards i buy have those little annoying suction kups that fall out when you take off the top, so my solution
since the keyboards i have, have a clear plastic with the traces in it
cut small holes in the bottom, and some in the top key area, and that would work w/o losing all the suction cups
or you could just try to route the led's in the key area, but that would be somewhat cramped unless you drilled out some of the unused space
fiji
fiji
berlin
ok let me explain more, ok so you have your standard keyboard with 3 sections the bottom plastic layer, the electrical layer with all the components, and the top plastic layer and keys
ok the electrical layer on all of my keyboards is a clear plastic, with traces (ex the little lines on your pcb that carry electrical signals)
so what im saying drill holes on the top plastic layer, and the bottom plastic layer and then when you put leds on the bottom it will shine up through the clear plastic layer, and out of the holes you drilled on the top plastic layer
i say to do it this way because
when you use EL wire, often times its too thick
Excelsior
KITTENS!!! KITTENS!!! KITTENS!!! KITTENS!!!
i say to do it this wire because
All right sounds nice... My PCB for my keyboard layer has metal with it...
