- Apr 21, 2001
- Den Haag, The Netherlands
The end of the year is 4 to 5 months away till I will buy new parts, but that gives time to check out parts and discuss them.
Main parts involved so far:
Case: Lian Li PC-V300
CPU: Intel Core 2 Duo E6700
Radiator: Black Ice GT Stealth 240 (dual radiator)
Pump: Laing DDC-1T with an addon to have a top inlet
CPU block: Alphacool NexXxoS XP
Tubing: 8mm ID/10mm OD (I think this is 3/8"?)
Fans for radiator: Papst 4412F/2GLL - 120x120x25mm
I won't be using the system too overclock like crazy, but knowing my past with overclocking I might try just a bit too see what the CPU can do.
Now the main things is this. I want a very silent system, so I checked which fans are very silent but still do enough airflow for the radiator.
The specifications of the fans are as follows:
* Type: 4412F/2GLL
* Dimenions: 120 x 120 x 25 mm.
* Power: 0,72 W.
* Rotations per minute: 1200 RPM.
* Airflow: 70 m³/h
* Voltage: 12 V
* Connector: 3-pin
* Bearing: Sintec
* Noise: 18 dBA
18 dBA sounds very nice too me, but will 70 m³/h be good enough?
A model higher, the 4412F/2GL does 94 m³/h / 55,3 CFM but has a 26 dBA noise level. Times two that would probably mean noise I might start to hear.
So, the basic question is will this setup cool the CPU effectively or would the 4412F/2GL be advisable?
I have done watercooling before, but that was more agressively and not really tuned to be being quiet.
The system will be build like neogenesis2004 is building his in this thread using these pictures. I might change/add some things too my liking, but the general idea is how he does it.
Thanks in advance for any responses.
* Type: 4412F/2GLL
* Power: 0,72 W.
* Airflow: 70 m³/h
* Voltage: 12 V
* Connector: 3-pin
* Bearing: Sintec
* Noise: 18 dBA
