If you've overclocked a radeon 8500LE
zabomb4163
i just got my radeon8500le from newegg today
(yes i know its cheap, that why i bought it)
because of some advice i got from a freind who overclocks alot, i bought a slot fan with the card.
my question is- How high can i go before its dangerous?????
he told me i can go to 320 but i think it sounds nuts. what do you guys think?????????
imput appritiated
Mr. Chambers
Iowa
imput appritiated
well.. good luck getting it to 320.. although its possible, but you'd have to have a heck of a card, and some very nice cooling - not to mention a vmod would almost be a must. most get them to 300/300 on air, stock... the only way you'd damage the card is if you ran for long periods of time without good cooling, or if you messed up on a volt mod and fried it that way.
funnyperson1
Senior Member
with a good upgrade of your gpu cooler, you could probably breach 300-310 on the core, and the memory should be fine past 300....but 320 is kinda iffy
Cisco Kid
Senior Member
thestramel said:
You'll need to upgrade the hsf for the gpu. A crystal orb would work quite nicely. You'll also need RAM sinks. The volt mod isn't absolutely necessary.
Ram sinks do absolutely nothing in most cases, mine will run 306/310 and that is what I scored my highest 3D mark score on, my sig shows it as 300/300 cause thats what I run all the time.
I think truly my card will run 310/315 with no volt mod but it does have an alpha IU cooler on the gpu with ASII on the gpu.
cisco kid
i will give a go you can bet that
