- Nov 5, 2013
- Ottawa, ON
Okay so, I just installed my Samsung 970 Evo Plus 500GB the other day. I moved some files to it (specifically World Of Warcraft and a few other files) I run the files and a few programs for monitoring my HDD's because one of them is on the failing side and I noticed that all three programs I installed (Crystaldiskinfo,HWmonitor, and Diskcheckup.) showed my temps at between 60 and 65C when I ran the programs and WoW at the same time. Which are apparently dangerous temperatures that would destroy my drive quite quickly (Apparently a year or less).
So I went to Toms Hardware with this problem and they told me that all NVME drives are running on the hot side and that my main problem is sticking a video game on my SSD and that's why It's running so hot. So, I tried moving World of Warcraft to my 250GB 840 EVO on their recommendation ran it, and my temps on the 970 evo plus were still in the 40-45C range. Which... is bad isn't it for just running pretty much completely idle and just running windows? As most of my other drives run at less than 10C while idle. Also when I'm putting the 840 EVO under a larger load than I put my 970 EVO Plus It's still running at a healthy 25-29C. So... what's the problem here?
Now to my main question. I was going to buy a 2TB 970 EVO Plus when I had the money for extra storage and because I wanted to stick several games on it for increased performance (Because despite the temperature issues WoW does run BEAUTIFULLY on my 970 EVO plus. Quite fast.) but, if all of my NVME drives are going to do the same thing what's the point in even owning one? Sure windows boots up in 2 seconds and my games run lightning fast but if they're going to blow up in less than a year under minor workload... what's the point in owning one? Am I missing something? Should I take the plate off and see if that cools it down (I'm using a ASUS Prime z390-A motherboard)? I have proper airflow going on in my case I believe. I just don't get why it's running hot unless toms hardware is right and It's a manufacturer error with all NVME SSDs. In which case it'd be extremely stupid of me to buy a 2TB drive.
