- Aug 1, 2014
I have a asrock z97 extreme6 and arc midi R2. The Arc comes with its own fan controller and it came with 3 140mm fans. One in the front one in the top and one in the back. I took the one in the front and put 2 in the front (as I put corsair h100i cpu cooler). My dilemma is what is the best option for cooling. Should I connect the fans into the MOBO and let it control the fans or should I use the R2 voltage controller (5,7,12). If I'm reading the manual correctly the case has 5 fan controllers built in. The only thing I don’t understand there Is a 4 pin cpu fan and right next to it a 3 pin cpu fan (The h100i connects with a 3 pin though there's only 1 actual connection in the connection). Is the speed controller on the case or connect to the MOBO?
Thanks,
Sebastian
Thanks,
Sebastian
