I'm gonna make an oder, which one of these has the most potential
Wiz4rd
I'm gonna make an order, which one of these has the most potential
I'm running good air cooling. I have a 2100+ right now but it's a crappy stepping and tops out at 2143mhz. A lot of people are getting the 1700's. my question is what cpu on this page should I go for. I want to be able to hit 2.4 ghz or maybe even 2.5
My cooling consists of an slk-800 and a 120mm fan pushing 119 cfm of air.
I'm just worried if I get a 1700+ I won't be able to hit 2.4 or 2.5 with my cooling. I'm really leaning towards a better stepping on the 2100+
I would love to have an opinion. Also please let me know WHICH of the 1700's or 2100's you would buy from the list.
http://www.excaliberpc.com/default.php?cPath=178_186&osCsid=7866cc9a5cdeb4e9d1ce57cf1ebefc6b
Wiz4rd
Wiz4rd
Well since noone replied, I went and bought this one.
AMD Athlon XP1700+ 1.47GHZ 384K 266 Tbred (TRAY)(JIUHB:0310XPMW)
Methusela
Most definitely, the 1700+ DLT3C JUIHB 0310 WPMW or XPMW.
They'll get you just as far as any 2100+, if not farther, on average.
Get them while they're hot!!
Methusela
djeff
Philadelphia, PA
Methusela
From what I've seen, you'll be happy with that 1700+ stepping.
mrpops2ko
get this 1
AMD Athlon XP3200+ 2.20GHZ 512K 400Mhz BARTON Processor (BOX)
lol its the best
altec
polka dot ninja
Doylestown, PA
You will be happy with the 0310XPMW, it is one of the best right now, along with the 0307's. How did you manage to fit a 120mm fan on an SLK800?
Wiz4rd
Wiz4rd
I took the 120mm fan and ground the corners off so the clamps would come around and fit. It does overlap the heatsink quite a bit but who cares. I could get better cooling if I found a way to channel the air better but this works good to.
dmon
Watertown,CT
$82 for a 1700-0310 xpmw. I just sold mine for $55. Good chip my mobo stopped me at 2.4 but the guy who has it now is at [email protected] and still going up. (watercooled & a pelt) What mobo do you have? Its not always the CPU that stops your oc. My ASSUS won't go over 2.4 no matter what chip I have in it and thats with all 3 volt mods done.
Wiz4rd
Wiz4rd
I have a Epox 8rda. I plan to do 2.4 ghz with my current cooling setup
altec
polka dot ninja
Doylestown, PA
With the 1700 0310XPMW and an EPoX 8RDA I think that 2.4 is a reasonable goal...good luck, and keep us posted.
Taneh
United Kingdom
I have a xp2500 as well and run it as a xp2800 (2100 mhz)
Would upping the fsb and lowering the mulitplier speed things up.
Also im running the standarn heat sink and fan and my temp is like 35 c max
Now i know u all say the standard hsf are ****e but it seems to keep things cool,
grunjee
Tri-Cities, Washington
Well I see you waited 21 minutes for someone to reply, sometimes you gotta give us some time!
But it looks like you made a good choice. I just ordered one of them myself from excaliberpc. :D
Hopefully I don't get a dud.
