- Apr 20, 2002
- Huffing Water Wetter
Here's the low-down.
I'm at a point where my Asus A7N8X can't give me the Vcore I want without Vmods, so I went out and got an Abit NF7-S.
Here's the problem.
The bottom plug is the power connector for my Vantec Stealth 550. The top plug is a standard ATX power plug.
As you can see the Vantec plug has four extra pins on the left side. I suspect they are the AUX 12V that are usually a seperate plug but have been incorporated into one plug. The NF7 requires the AUX 12V, but the plug isn't right next to the ATX plug on the motherboard.
So what I need is confirmation that the four extra pins are indeed the AUX 12V. If so, does anybody see any problem lopping off those four extra pins in one chunk so I can have my seperate AUX 12V plug?
Here's the problem.
