- Mar 16, 2001
- Chicago, IL
Ok, this is my first try at running an AMD processor. First, here are my current specs:
Epox 8K7A+, 1.4g tbird, millenium glaciator, case sides off
cheapo vcard, no HD(yet)
full tower case
I'm still in the building stages, so the furthest I have got is into bios and I have no HD in yet, just using a dos boot disk.
Anyway, I fired this thing up and got into bios right away to check out the temps. Its started in the low 40s and every few seconds would go up a degree...til finally ended up resting about 52*C!! Now this is under no load at all, just in the system bios. Now I know these chips run hot, but isn't that a bit much? The heatsink is fairly warm to the touch, so it appears to be doing its job. Is this what I am to expect? do all you guys just load up on case fans to keep temp reasonable?
I have various case fans in place and will use them once I make sure my PS is good enough (300w PC P&C turbocool). I see others with temps in the 40s and thats about what I expected under idle conditions and maybe in the 50s under load, but with what I have now, if I put it under load I'd be in the upper 50s or maybe even 60s!! What do you all think?
full tower case
