i'm running folding right now but...
livingelf
I need more info here is wut i need.
1. how do i register to view my poitns.
2. How to check how many points i have,
3. wut is the best fold to run for maximum points(im currently using FAH3Console.
4. And how do i get pepe to run under me so i get more points.
first of all
the config is done when you setup your folding client
second of all the page to check you stats is:
http://folding.stanford.edu/
next of all to get the maximum number of points per wu you need to be running the command line client
once you have that downloaded...create a shortcut and then right click on this short cut...after the "" add the flags -advmethods -forceasm then click apply
after that double click that shortcut and you should then be up and folding gromacs
as far as getting others to fold for you...ask around you never know who will be up to help you..
any other questions that you have probably can be answered in the faq on the team's website
located here : http://folding.octeams.com
welcome to the team
and another thing if you have an irc client i encourage you to visit us on the zirc network under the channel name of #ocfoldingteam
if you don't have a irc client then goto the front page of the team's website and check out filip's post
scoobiedoo
thanx man. wow i was running a complety dos based clien, this one that i just downloaded is more windows friendly although i im afraid will lose all my old work, no biggy, but i will try to finish a project so that work i did is productive.
