- Mar 11, 2001
- Mississauga, Ontario, Canada
Ok, first I want to apologize for posting the topic about Abit BE6-II, because I've seen how many times it was mentioned before, and you probably are tired of seeing the name, but I just have a few q's about it.
I'm planning to buy it because my VH6 doesn't give me good voltage, and I need to build a second comp anyway. I've done some research on BE6-II, but I couldn't find much, so here it goes:
1) What are the FSB settings, I've looked and I think that you can go over 100, even have 111MHz FSB, but I'm not sure. (I checked CPU database)
2)Will an Alpha PAL 6035 w/Y.S.Tech fan fit on it? (this is an optional question)
I am planning to run the following on it=>
Celeron 600@a gig (cB0),
20Gig Maxtor 7200RPM,
cdr-w, dvd,
Sound Blaster AWE32(the old and crappy 16-bit one, but I'll get a Live later on.)
250W PSU
If you think there would be some problem in the configuration, please tell me.
Thanks for your time!
cdr-w, dvd,
250W PSU
