hey everyone, im new to overclocking, i would like to overclock my system but im not entirely sure where to start, here is a list of what im running with.
i hope ive placed this in the right area of the forum. this is a double post because i couldnt figure out how to delete my old post.
cpu: Intel core2 quad q8200
mobo: gigabyte ep45-ud3r f12 bios
cpu cooler: arctic cooling freezer 7 pro rev. 2
cpu thermal greese: arctic silver 5 applied as specified on website.
northbridge re-greased with arctic silver matrix used pea sized dot in middle of chip technique.
gpu: sapphire radeon hd4870 1gb
gpu cooler: arctic cooling accelero xtreme plus with vr001 accessory kit.
case: thermaltake element s without side fan.
case fans: 2 enermax magma red blade ucma12 fans in the front, 1 enermax magma red blade ucma12 in the back, thermaltake 233mm fan that came with the case in the top.
the fan layout is this: the two in the front are used as intake, they are plugged into sysfan1 and pwrfan, the 1 in the back is used as exhaust and is plugged into sysfan2 the top fan is plugged into a molex connector and is also used as exhaust.
psu: ocz gxs700 or OCZ GameXStream 700w psu
hdd: 2x 100 GB 2.5" Hitachi Travelstar 7K100 7200 RPM HDD RAID 0 on the slab above the psu.
2x 250 GB Seagate ST3250318AS 7200 RPM HDD and 2x 1000 GB Seagate ST31000528AS 7200 RPM HDD in the last 4 slots on the hdd rack.
ram: 2x 4 GB Kit OCZ Platinum 1066 MHz DDR2 Matched Pair RAM 4 sticks total
sound card: M-Audio Audiophile Delta 192 Sound Card in last pci slot
wireless: pci-e wireless n ralink rt3090 in top pci-e slot.
optical drive: lg 18x sata dvd burner. in second 5.25" slot
card reader: 18 in 1 card reader usb2 in 3rd 5.25" slot
cable management: i have moved almost all cables completely out of the way using the cases cable management.
room temp: my room temp is usually around 20-30c, 30c during the day, 20c at night, i mainly use my system at night.
i would like to know the best settings to overclock my system, i want to use all manual settings in my bios if possible.
thank you for all your help
