In Theory
Forsaken
Hey Guys and Gals in theory what would this set up OC too ?
TY in advance for the help :)
Qty Product Item # Unit Price Qty x Price
ANTEC Performance PLUSVIEW Model PLUSVIEW1000AMG- with Side Window Snap-On Fan Clips Retail ***No Power Supply***
Specifications:
Color: Antec Metallic Gray AMG color
Material:Steel
5X VANTEC's Tornado (Double Ball-Bearing) Fan.
Specifications:
Model No.: TD8038H
Dimensions 80x80x38 (mm)
Rated Voltage: 12V
Fan Speed: 5700 R.P.M.
Air Flow: 84.1 CFM
Bearing type: Double ball Bearing Retail.
ABIT IC7-G, Intel 875P chipset for Socket 478 800MHz Canterwood ATX Motherboard RETAIL
Specifications:
Supported CPU:Intel® Pentium® 4 Socket 478 processors
Chipset:Intel® 875P / ICH5 RAID
FSB:800/533MHz
RAM:4x 184pin Dual DDR 400 Max 4GB
IDE:2 x Ultra DMA 33/66/100 Connectors up to 4 Devices
SATA:4 x Serial ATA 150 Connectors up to 4 Devices
Slots:1 x AGP PRO, 5 x PCI slots
Ports:2xPS2,1xLPT,1xCOM,2xUSB,1xLAN, and Audio Ports:
Onboard Audio: 6-Channel AC 97 CODEC
Onboard LAN: Intel CSA Gigabit LAN
ATI OEM SAPPHIRE RADEON 9800 PRO 256MB DVI/TV 8X AGP
Specifications:
Chipset:ATI RADEON 9800 PRO
Memory:256MB DDR RAM
Bus:AGP 8X
256-bit memory interface
First to fully support DirectX® 9.0 and the latest OpenGL® functionality
New SMARTSHADER 2.1 technology allows users to experience complex, movie-quality effects in next-generation 3D games and applications
128-bit floating-point color precision allows for a greater range of colors and brightness
Ports: VGA + DVI + S-Video
Antec True Control 550 Watt Power Supply With 2 Fans 5.25 Control Panel- RetailTrue Control is a 550 Watt TruePower power supply with a special external control panel that gives you the flexibility to adjust the main output voltages and minimum fan settings for peak performance.
Features: User-adjustable, individual dedicated circuits for main +3.3V, +5V, and +12V outputs
ATX12V for use with AMD and Intel based systems. Aux. power and +12V connector. Backwards compatible with previous ATX standards
Intel Pentium 4 / 3.0CGHz 512k socket 478 Hyper Threading Technology 800 MHz FSB
Specifications:
CPU: 3.0GHz
Type: Pentium 4 Northwood
Cache: 512K
BUS: 800 Mhz
Socket: 478
CORSAIR MEMORY XMS Extreme Memory Speed Series 2x 512MB 32MX8 PC-3500C2 With Platinum - Silver Heat Spreader.
Specifications:
Speed 434MHz
Organization 64M x 64
CAS Latency 2-3-3-7-T1
MITSUMI D359M3 3.5 floppy
Western Digital Raptor 36GB SATA WD360GD 10,000 RPM
PIONEER INTERNAL ATAPI 16X DVD-ROM MODEL DVD-120
Specifications:
Interface: ATAPI EIDE
Data Transfer Rate:
DVD-ROM: 8910~21600Kbytes/sec. (6.6X - 16X)
CD-ROM: 2586~ 6000 Kbytes/sec. (17.2X - 40X)
Average Random Seek Time: DVD-ROM 85ms CD-ROM 80ms
Average Random Access Time: DVD-ROM 95ms CD-ROM 90ms
Horizontal or Vertical Mounting Capabilities
MTBF: 100,000 POH (20% duty)
Swiftech MCX4000-B Heat sink
fiji
berlin
do you realise that will be SOOOO loud? im talking vacuum cleaner here
slk-800 is uber cool im a slk-800 fanboy eheh
F
Forsaken
Well all water cooling isnt out of the question for me so lets just say a stock h2o cooled rig with the above mentioned hardware
what speeds do you for see with it OCed ?
fiji
berlin
i dont know alot about intels, but id say prolly ~600mhz
but if you go water cooling, stay away from the stock kits
and better to buy all the best parts
if you just get a stock h20 kit youll prolly see little diff between that and air
