matthroberts
- Dec 31, 2013
Hello all!
First time posting here, so I apologize if this question has a very obvious answer. I built a new system in early January of this past year, but because of budget constraints, I pushed off upgrading the GPU until yesterday.
However, now I'm worried that my ability to overclock my CPU and GPU will be hampered by my PSU. I'm currently running a modest 4.2MHz OC on my 3570K, and I just ordered the ASUS GTX 760. I know stock TDP is 170W, but in reviewing the overclock of the card here on overclockers.com, the card can pull upwards of 273W in testing.
I have a 620W PSU (Antec NeoECO 80+ Bronze), and in running calculations this morning, I'm worried that I may not have enough head room to overclock the CPU and GPU. Can you guys give me any guidance on whether OCing both is reasonable with the components I've given? I'd appreciate it.
I will say that I'm less concerned about synthetic environments and more concerned with actual usage. Thank you, thank you, thank you if read this far
Full component list is below in case it's helpful or needed.
- i5 3570K
- ASUS GTX 760
- Antec NeoECO 80+ Bronze 620W
- ASRock Z77 Extreme4
- Corsair Vengeance 8GB (2 x 4GB) DDR3 1600
- LITE-ON DVD Burner
- Western Digital Blue 500GB
- Western Digital Blue 1TB
- i5 3570K
- ASUS GTX 760
