- Dec 16, 2001
- VIctoria, BC, Canada
Hi,
First off, I'm not sure this is in the correct category, so mods, move away I posted it here because the RAM is one of my main suspects in this problem, and this forum gets a lot of viewers.
Alright, this is regarding my brothers computer. He has:
-Soltek SL-75FRN2-L NForce2 200Mhz SocketA motherboard
-AthlonXP 3200+
-512MB Samsung PC3200 RAM (just cheap value stuff)
-Built by ATI Radeon 9500 Pro
-WinXP Pro SP2
His computer was working quite stable until he recently clicked on a virus that he had caught over MSN. The virus caused his computer to freeze, and upon rebooting, windows would no longer load. It would just reboot during the boot sequence. I tried restoring to last known good configuration, and to boot into safe mode, but no luck. So next, we decided to reinstall windows. We did so, and booted just fine. I though all was well, but soon my brother came to me with random reboots.
My first suspect was a poor PSU. Then I remembered he was using the same as me, a ThermalTake PurePower 420W. Not exactly high-end, but not generic cheap stuff either, and mine's been great. Anyways, I set up motherboard monitor to log every second, and told him to use his computer and told him to call me for the next reboot. He did, I checked the log, nothing. All voltages fine. 3.3v=3.38 5v=5.05 12v=12.27.
Next I realised that since he had just reinstalled, that windows was probably set to autoreboot on BSOD. I disabled that feature, so we started getting BSODs. Further proof that the PSU is OK. The BSODs pointed to various drivers. A different one on each reboot. So I decided, a full format was in order. However, while running booted off of the XP CD during the format, we got a BSOD. Hmm, couldn't be the drivers or a corrupt XP install then.
My next guess was heat. His CPU is hot, but his HSF is rated for a 3200+, and he is below AMD max temp. His on die temp is 60-65 MAX. I had a spare 120mm fan laying around, so I jurry-rigged it onto his PC with elastic bands )) and pointed at the CPU HSF and the chipset, which is passively cooled. He was able to get through a format no problems now, and I though great, problem solved, we'll get a new HSF.
However, it wasn't that easy. He was still getting unstable preformance, and more than normal crashing. I decided to run a Memtest86, since it is cheapo RAM. After a full night, it had found five errors. Hmm. Not a huge amount, but there should be zero. I thought maybe it wasn't quite able to handle PC3200 speeds at stock voltage so I went to 2.7. Ran for another night and got the same 5 errors. I now have a primary suspect. I have some more RAM coming soon, so I will be able to try that out, as I will have a spare 512 module.
Anyways, he tried installing NHL2005 today. The install went well, but in the game, there are several graphics glitches. The players will kind of flicker, or turn into black shadow shaped at the wrong angle to the ice every once in a while. The shadow shapes get bigger and smaller. I doesn't really hinder gameplay, since it only happens every once in a while. However, after about 2-3 minutes, or at the most 10, the game will either freeze, crash to desktop, or cause the computer to reboot. Normally I would say this is probably the RAM problem, but this video card has had a traumatic experience. I posted this in the "What's the stupides computer mistake you've ever made" thread:
I was testing out a video card for someone. It was a 9550 pro, so I devided to use my brother's computer since his video drivers wouldn't need to be changed. I put the computer on its side, took out the 9500pro, and laid it on the drive cage. I put in the new card, and turned on the computer. Everything boots and works well. Good, I thought, now I'll put the old one back in. I look down, and to my horror realise I had forgotten to remove the MOLEX plug from the side of the card! It was laying on the metal drive cage, all solder points short circuited together, POWERED! I went to carefully pick it up, and the second I moved it even one millimeter, the whole thing erupted into spaks. I pulled the power cord from the PC as quickly as I could, reinstalled the card and turned it on. It worked just fine since.
So, with that in mind, I moved the 120 mm fan so it was covering the chipset, and the video card, because I really don't think CPU temp is an issue. No change. I updated the BIOS and restored BIOS defaults, no change.
So, if you're still reading, to recap:
1) RAM, likely, shows errors
2) GPU, likely, but less so. Has worked well since "incident"
3) Temp, unlikely, since it has never been an issue before.
I just find it strange that there were no problems before the virus! Can modern viruses actually cause hardware damage like some were able to years and years ago? I was under the impression that that wasn't a concern with modern viruses.
Thanks in advance for any input!
-AthlonXP 3200+
-WinXP Pro SP2
