Install problem
myrockfight
Tampa, FL
I just installed windows on my new system. The first screen now says "To begin, click your username." However, there are no usernames, the mouse doesn't work, and from what I can tell neither does the keyboard. What gives?
Ok. The keyboard actually works. I hit ctrl alt del to see if I could restart. It won't let me restart, but it is asking for a username and password. This is the first time I have ever installed this...how could it ask for a username and password?
which version of windows? XP?
when you installed it were you asked for a name or password?
you can try typing in administrator for a user and no password.
Now this....
I am getting these error messages....
Error:
Setup had problems registering the following OLE control DLL:
C:WINDOWS\system32\swprv.dll
Contact your administrator, who may prvide assistance in diagnosing this problem.
Error:
The digital signature catalog D:\I386\NT5.CAT could not be installed. The error code is 6be.
The remote procedure call failed.
The signature for Windows XP Home Edition Upgrade is invalid. The error code is 6be.
Fatal Error:
Setup failed to install the product catalogs. This is a fatal error. The setup log files should contain more information.
Any ideas on this? This was after running the repair for Windows. (It is XP btw)
Try logging in as Administrator. You can also use WRC from the windows CD (Windows recovery console)
