Install windows 7 without dvd writer??
LeonX
Uruguay
Is there a way to install windows 7 without
Dvd Writer or Usb pendrive...
I mean, put windos 7 files in a folder and install
using the folder like this...
"C:/Windows7/(an exe?)".
or maybe i create a new partition set it as bootable
drive, and put the files or the ISO(i have the original DVD!!
no to piracy!),also tell me something good for partitions.
Xtreme Barton
i installed windows 7 from xp on a seperate partition .. while in xp i just created my new partition and stuck the setup in a folder on the new partition.. then i just ran setup and then it did what it needed to do then re-booted and finished up ..
i used partition magic 8
LeonX
LeonX
Uruguay
please gimme the steps i will appreciate that :D.
And i want to install in C: if its possible..
my hdd is:
1 partition C: 99gb primar
2 " " D: 50 gb aprox... the backups and all that stuff..
So, do i just start the "updater" or sorta thing?...
LeonX
LeonX
Uruguay
IM IN TROUBLE!!
So,i have to urgently upgrade 2 win7.
And i dont have a dvd writer, and i dont have a pendrive :S so, that`s the problem , im sorry its too hard for me..i will appreciate your help :D
Im quite in a problem now ... hehe
johnz
I wonder if you could mount the .iso in a virtual drive, and install the way you did.
Edit:
If you want to try the virtual drive, I use this...
http://www.magiciso.com/tutorials/miso-magicdisc-overview.htm
You're on your own from me though, as I've never tried installing an O/S that way.
LeonX
LeonX
Uruguay
Edit:
How about if i use DOS to directly install the files this way.
1) i copy the Windows 7 ENTIRE dvd files to the "X:" partition (15gbs)..
2) i use DOS or something to "boot" it, if it is possible..
3) i start installing in the C: partition, because de D: is the backup
4) i merge the X with the C
Lol im watchin`family guy :D 5 am in the morning and still in this thing :p
Merry christmas!
Xtreme Barton
i didnt have o mount anything .. if youhave an iso just get magic iso or somethig of the sort and extact the iso image to which ever partition you want to install on .. then just run setup ..
LeonX
LeonX
Uruguay
so, right click, extract, run setup.exe, choose where to install?... easy?...
LeonX
LeonX
Uruguay
my neighbour copyed the ISO from his computer, and transfered me the iso via wireless, (the router)..
Dont worry :p im against piracy...well... when i have some money.. this one is in english(my 7), cuz my cousin brought it from USA.. and anyway there is an language update i guess..
And, so that will work?...
Xtreme Barton
well i never said anything about piracy .. and by the number of times you mentioned it i think i will retire from this thread & let someone else take a crack at it (no pun intended) :D
