Installing Windows XP onto a FAT32 partition
Evlich
Hello, is it possible to install Windows XP Professional on a FAT32 partition, and if so, how do I do it. I am working on a dual boot system, and since linux isn't very good at writing NTFS I think it would be much more convenient to boot with FAT32. Thanks a lot.
E
Evlich
I figured that you could. But when I go through the thing to select the partition that I want to install it on, it says I have to format my drive and it only gives me the options of NTFS and NTFS (quick). I tried going into the console and using the 'format' command to explicitly format the drive in FAT32, then I used the 'diskpart' command to make sure that it showed it as FAT32, and when I boot into the installation program, it says that the partition type is unknown and it gives me an option of formatting in NTFS or NTFS (quick) again. Any suggestions? Thanks.
E
Evlich
I found that I have to format with less than 32 gigs. Apparently, windows XP can't handle 40 gig FAT32 partitions.
Know Nuttin
Senior Member
Ontario, Canada
XP cannot format more than 32gb during the install. Best way to do it is to use a windows 98 bootdisk, create the parition and format it using the bootdisk, then run the XP install and tell it to leave the file system intact.
Blimpie
Hey, its microsoft. Dont expect everything to work properly all the time.....
Anyway, Know Nuttin, is correct. Go to bootdisk.com, get a 98se boot disk. Boot to that, and format the drive, it will automaticly format using fat32, then run your xp install, and choose to leave the partition in its current state (dont format it again), and your set to go....
