bfmctango57 said:
Will that new mobo support my ram? No eh!?
Kingston 1GB KIT DDR400 PC3200 CL3 (3-3-3) DIMM
What is the 805 you are talking about?
Is that the socket or the chipset? Can you please post some links so I can see?
What is C2D?
What is e4300?
What is 805?
hi, sorry, some things i just take for granted.
the motherboard i talked about (
here) will run your ram just fine. it will also run your video card, whatever that is.
the 805 (
linky) is an intel CPU. it is basically a dual core prescott that runs at 2.66ghz and has 1mb of l2 cache, no HT. it has a stock fsb of 133. and a multi of 20 (20*133=2660mhz). if you run it at 180fsb, that will give you 3.6ghz, which should not be a problem. some people get more. the 805 is a LGA 775 cpu, not socket 478. meaning its a Land Grid Array cpu, it has no pins, only gold pads. the pins are in the motherboard instead nowadays, instead of on the cpu.
C2D is short for Core 2 Duo, Intel's newest and fastest processors. they replace northwood's, and prescotts, and everything Pentium4. they run at much lower clockspeeds, and get way higher results. they are all dual core, except the Qx6700, and all have a default fsb of 266. the e6300 in my sig has a default speed of only 1.86ghz, but it would smack around a 4ghz prescott. at 3.5ghz, there isn't a P4 on the planet that can run with me day in, day out, 24/7. the current Core 2 Duo's available are the e6300 (1.86ghz, 2mb cache), e6400 (2.13ghz, 2mb cache), e6600 (2.4ghz, 4mb cache), e6700 (2.66ghz, 4mb cache), x6800 (2.93ghz, 4mb cache) and the Qx6700 (quad core, 2.66ghz, 8mb cache total).
the e4300 is a cheap C2D that is due out in january. it will run at 1.8ghz even and will have a stock fsb of 200, which will make it much easier to overclock on cheaper mobos and with cheaper ram. on the mobo i mentioned, it should be able to do 2.6ghz no problem, and that would totally destroy either a northwood or a prescott at even 4.5ghz.
hope this helps some, fire away any more questions you may have.
