Intel celeron motherboard
most deaf
my friend has a intel celeron (mATX) and he wants to overclock it, where are the jumpers. I think there is a jumper to move to make it go into config mode in the bios, which one is it. It came in a Tiny 333MHz pc(that is why he wants to overclock it)
For anyone to help you here we need to know the model and brand of the motherboard. There are several ways to figure this out if you do not know it.
1) Look for the motherboard manual that came with the computer.
2) Look on the motherboard itself. If you can find a model number, then you can do an Internet search with the terms: motherboard and "model number".
If you are lucky the manufacturers name may come from such a search.
3) Use the program Sandra. It will often be able to read the name and model of the motherboard for you.
Once you have the model we might be able to help. Then again you might be able to look in the manual and find the answer yourself.
