- Mar 3, 2012
Okay guys ive never really messed and overclocked with these core 2 duo chips lol i was always messing with the Athlon 64 x 2 chips when these bad pups came out. lol anyways i got this rig found it in the trash bought 4 gigs of ram and started it up and bam it works? im like WTF mate? okay so it has the following specs.
Case: Apevia ??? 2 x front 80mm fans
1 x top 80mm fans
2 x 120mm rear in Water Cooling Closed Loop from Cyber Power Push/Pull
Ram: 4 x 1GB DDR2 667 @ 800 Stock Timmings & Voltage
450watt PSU Raidmax
Motherboard: Asus P5NE - SLI
GTX 8600 GSO x 1
1 x 320GB Western Digital Cav. Blue @ Sata II
Windows 7 Ultimate 64bit
CPU: Core 2 Duo E6750 Currently stable with 24 hour test of Prime 95 @ 3.15Ghz @ 1.5 Volts (JUST FOR KICKS!)
Idle Temps: 39/42 Max Load Temps under Prime 95: 55/59
Max temp for CPU: 70c I think?
Max Voltage: 1.5Volts.
Screen shots of cpu - z below
CPU-z Shows current vcore @ 1.472 have it set to 1.5 volts in bios
trying to overclock this thing to the max
and as we can all see for temps THIS THING HAS QUITE ALOT OF ROOM STILL!
, but i need some help as i have no expierence overclock with the c2d's! please help lol
if i try and raise the voltage pass 1.5 the max ive tried is 1.518volts and it wont boot but it also was tried @ 3.4Ghz also. since i have a lot of room for temps what is the safe vcore i could set it at? maybe a couple hairs above 1.518? im asking cause it wont boot with anything above 1.5 and below 1.518? so idk i didnt want to go any higher till i got some help and opinions!
so i can get it stable at 3.2Ghz with prime95 for12+ hours it was @ 3.24 ghz @ 1.5volts and let it run all last night in prime 95! so thats good i guess?
what can i do to further my OC! ???
thanks
Daniel!
1 x top 80mm fans
450watt PSU Raidmax
GTX 8600 GSO x 1
Daniel!
