- Mar 9, 2002
- The belly of the beast (Wales)
Hi Bing, I am planning on giving it a go fanless with and without using ducting. The CPU fan is inaudible anyway at the speed I use so it has no benefit acoustically, but if it saves the cost of an ultra low noise 120mm fan it’s a good thing.Fyi, on UVOC at certain casings model, its possible to go totally passive (fanless) on the CPU with high end HSF !
You should try it yourself sometimes equipped with Coretemp for watching how close the temperature goes until max Tjunction while with AC turned off, if it still under 20 degrees Celcius on load, I would say it is pretty safe for 24/7. .
I’ll still run it with a fan as the airflow helps cool the motherboard which is an issue with my mATX board which has a small Northbridge heatsink so it runs hot.
