FEATURED Intel Haswell i7 4770K & i5 4670K Results Thread!
hokiealumnus
Water Cooled Moderator
Ok folks, since the guide's spreadsheets didn't get embedded properly in the first post, we figured we should do this up right.
First off, if you haven't already read it to make the most of your overclock, go read our 3 Step Guide to Overclock Your i7 / i5 Haswell Platform
Now, this first post will be two forms - one for the i7 4770K and the other for the i5 4670K. The next post will contain the result charts.
Please be sure to use these guidelines when filling out the form!
Required Info:
  • 24/7 stable CPU overclock in MHz (i.e. 4.6 GHz = 4600, 4.625 GHz = 4625, etc.)
  • Vcore voltage used
  • OCF username
  • Verification screenshot showing multi-threaded stress test (host images here)
Good info to include:
  • CPU Batch # (Located on both the CPU itself and the retail packaging)
  • Motherboard
Optional, but welcome information:
  • Stress testing temperatures (in °C)
  • CPU Cooler
  • Did you use/like adaptive voltage? Why / why not?
  • RAM clock (in DDR3-xxxx)
  • RAM timings
Now, the forms:
Form for i7 4770K Overclocks
Form for i5 4670K Overclocks
Happy clocking!
hokiealumnus
What's a good form without results? We've got those too! The graphs should auto-populate with new data points when people fill out the forms.
4770K results
4670K Results
Janus67
Benching Team Leader
Cool form usage, looking forward to seeing the data results.
hokiealumnus
Hmm...that's a problem. When you fill out the form, it inserts a new line in the spreadsheet rather than using existing lines (which have formulas appended to the end to calculate the graphed results).
New plan - When you post a result, be sure to note that you posted one here in the thread, that way I know to update the form. I may update it right then or later that day, but expect a within-24-hour-update period as long as I'm near a PC. :thup:
Knufire
Senior Member
Manassas, VA
In less mathy terms, mean frequency is the average max overclock of all the people who have submitted to the form.
The delta from the mean frequency is how far off a single user is from the average.
hokiealumnus
Bump. Result charts updated to reflect a couple more submissions.
Should I sticky this thing or will it disappear?
||Console||
Sticky , Front page even if you can get bunch more ppl to make subs it should drive trafic to the site . I will post my sub next week when my gear arives
hokiealumnus
I'm sorry, I have no clue why you guys can't see it. They're both set to "Public on the web - Anyone on the Internet can find and view" :shrug:
Do either of you have a firewall that might be blocking Google drive?
dudleycpa
Don't have a problem seeing it. Does need a lot more data points before we see any "meaningful" data.
Xeon_KI
Toronto, ON
Yup! Corp Firewall looks like.
I can see it on my phone.
dejo
Senior Moment Senior Member
got my new chip today and was from the same batch as the one that would not do ibt at stock setting with any stability at all. the new one just has a few minutes of running, just booted it at 46x and 1.25v and was able to do a full wprime1024 without issues- other than getting a bit warm as I just have a hyper 212evo on it for now. it will see the ss soon or maybe even dice if the chip offers any potential.
very happy with it being way better than the first one
I also didnt enter it into the form yet as I really dont know what the potential is. I moved to 4.8 in windows and it didnt like it at the same voltage.
this was all done at 2133 on the ram as well
hokiealumnus
That sounds like it's actually a pretty solid chip dejo, great second choice!
