Hello!
I have a Intel i5-4690k proccessor, mounted on a MSI LGA1150 H97M-G43 motherboard.
The problem i am facing, is that i can not go beyond a CPU RATIO of 39 when i enter the BIOS.
I can type in 38, 39,22,24 etc. All numbers will lock and be ok, as long as it's under 3.9 GHZ.
But as you all may guess, i want to go higher. But the BIOS simply does not let me do that, and i'm completly stuck at 39 CPU ratio, or lower.
I'm also able to change the core voltage, and all other things i need to fiddle with in the BIOS.
I have tried to read up on the subject, searching around on Google but i simply have no luck on the subject.
I hope some of you smart gents, and probably girls in here can help me out!
Greetings from Norway!
PS!
The complete setup looks like this:
i5-4690k
Crucial DDR3 BallistiX 1600Mhz 8GB
MSI GeForce GTX 960 Gaming 4GB
Cooler Master Hyper TX3 EVO
PS!
i5-4690k
