Intel I5-6600k temperatures
Tsubaki
Hello, I just upgraded my CPU, motherboard and case to I5-6600k , Asus z-170 progaming and Zalman Z11 and decided to play abit with the OC. My GPU is a GTX 970 g1 gaming.
I managed to get 4.5 GhZ with 1.3V and ran an Aida stability test for 34 minutes, screenshot here: https://gyazo.com/4d341b5b5d237580acb5586740b99bd8
I'm using the evo 212 for CPU cooling.
Recently I played dark souls 3 on max settings, and my temps went up to 71-76 max on every core after 2 hours, unfortunately I don't have the screenshot ( measured with HW Monitor ).
Are these normal temps? Should I reduce the voltage / frequency for every day use?
T
Tsubaki
Thanks for the reply!
What is the temperature I should worry about my CPU life from? Or the one that it should never reach?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
The CPU will throttle itself at 100C. Keep it at 90C while stress testing and all should be well.
