- Apr 21, 2001
- The North Pole
The Intel Itanium is avalible in 733 Mhz 2 Mb L3 cache, 800 Mhz 2 and 4 Mb L3 cache. It looks like a FCPGA with about the same set of pins, but it is twice as wide and with a huge piece of metal on top it. Power consumption for the processor alone is 110 to 130 watts according to Intel specs.
Intel say this cpu can be used in configurations with 512 cpu´s, but it is also available in workstation configuration. The HP i2000 is marketed as a "latest technology" high end workstation, base price for a dual 800 Mhz is _$15.000_!! There is also a 4Gb memory upgrade avalible for a mere 8000 dollars. Memory type is PC100 sdram, not sure if it is registered/ECC or not.
Now what is this Itanium processor? What does it do that the ordinary AMDs and Intels doesn´t? How on earth is possible that fully loaded dual 800 Mhz workstation could cost $20.000? I put together a super dual AMD system on a retailers homepage: dual MP1900, 4Gb PC2100 DDR reg/ECC, ATI FireGL 8800 128 Mb DDR, mylex SCSI raid card, 5 x 18 Gb 10krpm U160 hddrives, tyan mobo, Lian-Li full tower, 550 watt PSU, Soundblaster audigy, DVD and it didn´t even hit $8000.
*edit* The dual AMD board could be shifted to a dual Xeon P4 board. It costs about twice as much as the tyan amd board, but it has onboard SCSI. The memory is also more expensive. But if the raid card i skipped and the onboard SCSI is used instead, the total price will still be about $8000, using dual Xeon 1.7 Ghz
regards,
Henry
regards,
Henry
