Intel mobo manuals
DW_UTjunky
i need to know where i can find the manual or some good info on my SE440BX-3 intel mobo.
im of course trying to overclock it and yes i know itels mobo are not that great for o/c'in
thanks
Hi! Welcome to the forums! The owner's manuals can usually be downloaded from the manufacturer's websites. If you don't know the make/model of the board, you can cross-match the BIOS ID (I think on motherboards.com) and find out who made it. If you aren't sure, post the BIOS ID (shows up on startup screen) back here and someone should be able to help.
If I read you right, this is an Intel board? Not sure, but you may be able to use SoftFSB to do that. Anyway, if it is an Intel board, the manual can usually be gotten here.
Good Luck!
Anthony
