Intel P4 1.6A
Bullermann
Germany/NRW
Hello,
I´m from Germany, my English is not very good, sorry.
My Problem is my brandnew P4 on an ASUS P4T-E with two 256MB PC 800 Samsung Rambus. I can´t overclock it, it doesn´t even start at 110Mhz FSB, use 1.5V at 1.65V---Nothing! What can I do, to overclock it?
Thank You for Answers
jdmcnudgent
tOLEDO, OHIO, the heart of it all!
do you have the jumpers in the right position. check the book for the position of the jumpers to use the soft menu and over clock it through the bios. too, bad about the asus p4t-e board that you got, the highest you will be able to overclock the chip will be 2128, a far cry from what you could get and would get with the rambus ram. look around in the intel motherboard section, one of the better rambus boards is the abit th7II. good luck.:D
JaY_III
Senior of BX
How hot is that CPU runnning?
And what do you have your RAM timming set to?
RAMBUS can be VERY overclocker unfriendly. Doesnt like out of spec speeds at all (next to good old DRAM)
