- Nov 21, 2005
- Atlanta, GA, USA
Next is the 100% OC
Ask and you shall receiveEvilsizer said:im waiting to see 400mhz from you!
*taps foot*
EvlUndrwareNome said:right now it is between this cpu and the e4300.
Only 20$ for double the L2 cache. I would really love to see someone run one of these with an 8800 series card and post some numbers.
I'll try to get some 3dmark runs to compare this cpu to both my e6600 and e4400 at the same clock speeds (I should have a 3200mhz run for each cpu posted in the benching section) in a few minutes. I'll edit this post with the different scores.EvlUndrwareNome said:right now it is between this cpu and the e4300.
sno.lcn said:I'll try to get some 3dmark runs to compare this cpu to both my e6600 and e4400 at the same clock speeds (I should have a 3200mhz run for each cpu posted in the benching section) in a few minutes. I'll edit this post with the different scores.
*Edit: 3DMark05 scores are as follows, benched on setup in my sig.
e4400 @ 3200mhz, 8800gts 320mb @ 660/960 - 17500 - verification
e2140 @ 3200mhz, 8800gts 320mb @ 660/960 - 16168 - verification
Also should be noted fsb is 320 for the e4400 and 400 for the e2140, both running 1:1 ram. With the e4400 up to 3500mhz I scored over 18000.
GTengineer said:I would spend $20 more and go with the E4300 if that is the actual difference in price. Just to give you an example and I don't want to take anything away from these CPUs because they look like amazing overclockers. But at 3.1GHz my E4300 runs 1M super pi at 17 seconds. That is 3 seconds faster at 100MHz lower clock speed. It is possible however that for gaming the difference is not as severe as cache is not as important.
My 2 cents
Evilsizer said:well for c2d once they have 2mb's l2 you will get the most from gaming. having 2mb more,going from 2mb to 4mb really only adds about 3-5% from past benchmarks.
I'll definitely shoot for it when I get back home in a couple of weeks (outta town again)Evilsizer said:hehe i knew you could do it.. now lets see 450mhz!! *cracks whip*
pscout said:Great oc's
It would make a nice folding rig if it had more cache. These days smp folding really needs 4 MB or else it is no faster than my 930d's ... although it does consume less power and produce less heat.
If it'll get to 400fsb you're good, that's 3200mhz and it wasn't hard at all. It's just past 400 where the chip seems to have trouble. Highest I've seen one so far is just over 3400mhzSam__ said:good lord those things oc well...im think i might invest...anyone got any ideas what i could get an E21XX too on the mobo in my sig?
