Intel PIII Xeon 550Mhz, Altera chipset
NWS
N E one know where TF I can find what mobo I have? No where on it does it fippin say who makes it!!! I need a jumper diagram, and for the life of me cant find one.
N E ideas?
Where did you get the box...is this an oem system??? If so then you can try and trace it back through there website or with a phone call...I am saying this cause I figure if you built this system you would know the mobo.
Copy down the bios string at the lower left side of the screen durring bootup...you might have to reboot a few times to see the whole string..after you do that, go to the respective bios manufacturer's website, and search for your mobo maker using your bios string, ...like if it is an Award bios, go to their site, and look up your maker.
Good Luck
