- Jul 15, 2007
- St. Clair Shores, Michigan
Wondering what others are getting for temps with the Intel Q9450.
Post your CPU cooler/heatsink, idle/load temps, temp monitoring program.
Freezone CPU cooler
Idle: 32C Load: 45C - (30 min in Prime95 on each core)
CoreTemp
Idle: 22C Load: 35C - (30 min in Prime95 on each core)
RealTemp
I'm deciding whether or not to replace my freezone cpu cooler with another high end air product such as a Zalman 9700 or a Scythe Ninja + fan. If my temps are relatively low, I most likely will keep the freezone unit.
EDIT: I have been trying to read up on temperature errors. Can anyone confirm or disprove that the new 45nm chips have a TJmax of 95C instead of 105C, which means core temp temperatures based of 105C are wrong and that my temps should be 10C cooler? Does Real Temp give correct settings for Q9450 at 0 calibration or does it need to be set to ++ + - --?
Freezone CPU cooler
CoreTemp
RealTemp
