Intel Virgin..
Assasin-UK
Im curious to know which is goin to be best for overclocking..
p4 2.4 or p4 3.2
Its going to be cooled using a vapochill XE by the way...
And theres no point in me saving money and spending it on ****
Cause theres nout to spend it on!!
thanks in advance...:D
If you want 4 Ghz+ easy, get the 3.2. My 3.2 with my prommy does over 4.1 fairly easily. If you want more of a challenge & insanely high fsb's then get the 2.4.
Keep in mind that you may end up having to run your 2.4 at 3.6 Ghz (300 FSB) due to mobo problems with going above 300.
Yeah, with air cooled or water cooled, I would recommend going for high FSB, but with a prommy, you want a higher multiplier. Whether you pick the 3.0C or 3.2C depends on what RAM you use and whether you want to run the 1:1 ratio. The 3.2C O/Ced to 4 gig would be 250 FSB and good PC4000 would handle the 1:1 ratio.
