- Apr 17, 2001
- Mexico City, Mexico
I've been playing with this idea.....
You can get a cold plate of 1/4" or 3/8" and drill a hole in the middle. Then mark the place the die will rest on the cold plate. Now connect the hole with a corner or the middle of the die. You can put the thermal probe inside the hole and seal it with sillicon.....That way you can have a thermal probe ala Joe without drilling all you heatsink.....you can easily swap heatsinks or waterblocks, add a peltier with the same probe.....
What do you think?
What do you think?
