iPanel vith Asus CUV4X-E
Henry Rollins II
The North Pole
Realized that Asus iPanel only cost about $20. That seem not to be very expensive.
Problem is:
I can´t find any specs/info about it on Asus´ own webpages, and as far as I can tell all tests/reviews of the iPanel only is toghether with the Intel 815 chipset.
There is an iPanel connector on the cuv4x-e as well, but is it really supported? It has a VIA chipset.
regards,
Henry.
I have always wanted to know this as well, but like you said there is no info on asus' web site about it. I am thinking of getting an i-panel. Have you tried the ipanel with this board yourself? How is it, is it worth it?
I plan to get a cuv4x soon do you recomend it?And what the heck is an i-panel???Pls tell me what you guys think about the cuv4x!!
I would recommend the cuv4xe its a good stable board. It has 6 pci slots, udma 100, and FSB settings from 66MHZ-153MHZ in 1MHZ steps. If you tweak the memory you can get quite good perfromance out of it.
Go here to find out about the i-panel.
