is 0.38v bad voltage from mbm5?
catman25
heres my specs. 300 powertech psu and my readings are
core0:1.80
core1:0.38v
+3.3///////3.44v
+5.00/////4.86v
+12.00////12.31
see anything wrong???i have 8 fans .ranging form 92 to 60. a blue neon light sound activated and a ultra violet cold cathode.geforce 2 ti..thanks for your help
psu is a powertech pt-300atx 165watt total+3.3 &5.0
motherboard is a msi k7t turbo
athlon xp +1700 (not overclocked)
pc 133 mem 1 stick 256 +1 stick 128
geforce 2 ti 2742 drivers
sound blaster live 5.1
ethernet card (kingston)
40 gigger maxtor harddrive
sony 8 x's cr-writer
acer 52 x's cd -rom
thermal take drtagon orb 3
1/ 12 inch neon with sound sensor
1/10 inch uv cold cathode light (fans are modded with glow in dark stickers.give a cheaper led fan mod apprerance.please some one fix my beoch...
Wonko The Sane
Port Richey, FL
I'm not familiar with that board. is it a dual processor board? if so are you using 2 processors? if you are only using 1 processor in a dual board core 1 will be very low (because there is nothing to pass the voltage through). if it's not a dual board, you can probably ignore the core 1 reading, although it might be interesting to find out where it is coming from. if you have 2 processors, then you may need a more powerful PSU. I've seen this on my board (bp6 with dual celeron 400's) and when i got a different PSU, it read fine.
