I've been running my 1080ti at 2063/6000 for about a year, and it has never crashed on highly demanding games, such has TW3, AC:O, Deus etc. I used to stress test about once a month to make sure everything is running fine using 3DMark Firestrike and Timespy, as well as running Heaven and Superposition in loops for extended periods (1h+).
Last month I started failing Firestrike ultra, even when I did pass it had relatively lower frame stability (~97%). On the other hand TimeSpy (extreme or ultra, don't remember how its called) always passes with 99%+ stability, never failed it once. Heaven and Superposition also don't fail.
Using those results, should I lower my GPU clocks a bit, or is Fire Strike simply producing bad results? Would love to hear your experience with GPU stability tests.
Thanks!
Thanks!
